ford 302 motor mounts? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-13-2013, 05:20 AM
Last journal entry: 27
with my old steering box set up.
i did have a bit of bumpsteer.
and when i stomped on the brakes it wanted to go to the right.
after the reversed corvair install the bump steer issue is gone.
and i got it up to about 50mph then stomped the brakes.
the diving to the right issue is gone as well.
  #17 (permalink)
Old 02-13-2013, 05:24 AM
i am installing these tomorrow
VROOM!
SKREE!
etc.
  #18 (permalink)
Old 02-13-2013, 06:07 AM
barrnone50's Avatar
Originally Posted by unclebill View Post
i got my new mounts and steering box installed.
[/QUOTE]
Those look pretty beefy. Very nice!! I might have to change mine will see.I did revise them. Hope they work!
Name:	motor mounts home made.jpg
  #19 (permalink)
Old 02-14-2013, 06:39 AM
Those look pretty beefy. Very nice!! I might have to change mine will see.I did revise them. Hope they work![/QUOTE]
the more i looked at my old ones the more i realized that the design itself was flawed because it makes the bolts the weak link.
these are more like a bridge abutment or something.
it ties everything together so nothing can go anywhere.
engine weight pushing down and that pushes the mounts against the inside of the frame rails
  #20 (permalink)
Old 02-16-2013, 05:16 AM
barrnone50's Avatar
The latest ones you made look like they will fit the bill. Again I am no engineer so make and test and see what happens. I to wonder the stress point or weakest link is at motor or at mount at the frame. Time will tell.
  #21 (permalink)
Old 02-16-2013, 06:59 AM
Wiki Edits: 27
look good.
I usually build everything, I have a lathe, mill, plasma, torch Mig, tig, press, E wheel, bead roller, saws, etc It's easier to try and not re-invent the wheel every time. I check out my speedway catalog, the Welder Series,TCI, SCotts, Morrison, CCR, RPM, Etc. info. There are some pieces that aren't worth the time and material cost to try to build myself. But my steel supplier will order full length's of DOM tubing for about 30 % of what some of the catalogs want. And I regulary check out their inventory of cut offs, drops, before they load it into the recycle dumpster. That goes by the pound about 20 % of what full lengths would cost.
  #22 (permalink)
Old 02-16-2013, 07:24 PM
barrnone50's Avatar
I agree with you on not trying to reinvent the wheel. But this is a hobby for me not a business and there is a certain satisfaction on building and fabing parts.Its like you could buy a car or hot rod already completed and save money,I have been told that many times,but I want to build a ride of my own,its not about money its seeing what I can do.And man it sounds like you got the gear to build anything you want.Someday I might be lucky to have a decked out Shed or Garage. Happy trails George
  #23 (permalink)
Old 02-17-2013, 01:52 AM
i do not have a single one of the tools you mentioned.
  #24 (permalink)
Old 02-17-2013, 04:16 AM
You asked about the kind of vehicles are in Sri Lanka.
All vehicles are right hand drive and they are Japanese,European and Chinese vehicles.
Ranaweera Sedere
59 Ford Motor Mounts LBL Hotrodding Basics 15 03-31-2014 11:43 PM
Putting a 302 in a 1962 ford falcon futura...Motor Mounts?? futuraresto Engine 3 01-26-2011 09:08 AM
'34 ford motor mounts lamothe1 Suspension - Brakes - Steering 6 08-19-2010 06:38 AM
49 ford motor mounts WeeWilly Engine 3 04-11-2006 09:23 PM
ford 302 on chevy 350 mounts topcat662 Engine 1 07-02-2002 11:41 PM
