Ford 302 Rear Main Seal - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-23-2009, 09:53 AM
I've got a 1986 Lincoln Mark IV 302 engine in a Bronco II with an automatic. Can anyone tell what rear main seal is in that year engine and how to replace it?
Thanks
Old 12-23-2009, 12:03 PM
tnsmith10's Avatar
when will it rain???
aound 85-86 is when they started going with a 1 piece rear main seal.
i recommend finding the casting numbers on the block and searching to see if that block calls for a 1 piece seal or not. that will keep you from doing any un-needed work. if its a 1 piece, then pulling the trans is all you have to do. if this be the case on a 1 piece seal, also while having it apart, that you check the crank where the seal rides on. they have a tendancy to wear a groove in the crank. carquest or napa should have or be able to locate a redi-sleeve kit that comes with a reddi-sleeve, and the seal together. cost is around 50 bucks.
if it is not a 1 piece rear main seal, then your going to have to pull the pan or remove the engine since you have it in such a small vehicle. the seal, (2 piece) will be located in the rear main cap.
Old 12-23-2009, 12:12 PM
Thanks
I appreciate your quick reponse. I will do that; I'll check the casting number.
buick rear main seal belairgauld Engine 2 08-24-2008 05:41 PM
SBC Rear Main Seal: Thinking Man Engine 12 03-12-2008 03:45 PM
Building A 302 Chevy Scorpio Shaping Flow Hotrodding Basics 6 01-16-2007 06:55 AM
Help On Chevy Rear Main Seal JimKramer Engine 9 02-07-2006 09:39 AM
347 Ford Rear Main Seal Nitrospud Engine 6 08-30-2003 03:33 PM
