Ford 302 Windsor overheating probs - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-13-2012, 04:21 PM
My 302 Windsor (32 roadster no bonnet all open)gets hot when in traffic,or idling for a period of time,when cruising its fine,replaced with Afco radiator,checked hoses,water pump ,maybe timing!!!,any thoughts
Old 03-13-2012, 04:48 PM
WDCreech's Avatar
Grumpy Old Goat Herder
Do you have a good fitting fan shroud on the radiator?
Old 03-13-2012, 04:59 PM
WDCreech's Avatar
Double post!
Old 03-13-2012, 05:49 PM
Irelands child's Avatar
Thermostat, fan shroud, under drive pulley(s), reverse rotation/counter clockwise fan on a standard clockwise water pump - or vice versa, timing should be about 8-10 degrees BTDC normally with ported vacuum on a Ford. You need a 15 psig(1 BAR) cap which will allow the boiling temp to go as high as ~250F(121C).
Irelands child
Old 03-13-2012, 07:55 PM
Last journal entry: 49 plymouth what
hot 302
could be head gaskets up side down
Old 03-13-2012, 11:23 PM
Over heating at idle
No shroud not enough room for one,as engine bay is all open,water pump has No fan blade would that make any difference!!!!
Old 03-13-2012, 11:45 PM
WDCreech's Avatar
If you have no fan, How do you expect the water to get cooled when your not moving?
Old 03-14-2012, 12:35 AM
Water pump
Water Pump is still turning!!
Old 03-14-2012, 05:48 AM
That's fine - except there is no cool (ambient temp)air being drawn through and past the radiator fins.
NO FAN = HOT WHEN SITTING STILL!!!!
Irelands child
Old 03-14-2012, 06:30 AM
T-bucket23's Avatar
Wiki Edits: 26
You have to have a fan, is there room to put a pusher fan in front of the radiator. These are not my first choice but they will help when there is no room behind the radiator
Chet
Old 03-14-2012, 10:55 PM
plan e
another thought men what if the heater radiator,which goes to demister under dash is blocked,????
Old 03-14-2012, 11:25 PM
WDCreech's Avatar
You will have nothing cooling the HOT water going into the radiator! The heater core cools very little.
Old 03-15-2012, 01:44 AM
Ok
Thanks blokes, got a fan coming, hope plan E works ,will be in touch again with outcome thanx for the help the Aussie.
Old 03-15-2012, 03:20 AM
New Member
I am fine!
Old 03-16-2012, 11:26 PM
Plan f
Fitted fan bit better still getting hot at idle speed after 10mins,(230deg) or in traffic how good are pusher fans,may have lengthen engine compartment to fit shroud'!!
351 Windsor overheating djaco Engine 3 08-19-2011 09:19 PM
Ford heater wiring Probs???? 427feracer Electrical 2 01-29-2009 06:58 PM
351 windsor into 58' ford 55 dude General Rodding Tech 1 12-08-2007 07:39 PM
ford f250 tranny probs 75sprintguy Transmission - Rearend 4 09-14-2006 07:01 AM
Ford Crown Victoria '89 electrical probs delrays Electrical 4 04-20-2006 07:38 PM
