Look at the parting line instead of relying on "it has the grain from sand". Wide= forged, narrow= cast.
From the first string of numbers you might decipher part of it as 302, 3.25" stroke w/a 5.4" rod. |
I really need the imbalance so I can figure out which flywheel I need for the T5. I have a late model 50oz but I'm 75% sure it won't work. That just leaves 28oz and 0. I really hope it's not a 0 but the Eagle guy identified it as a 4340 forged w/0 imbalance (until I told him there isn't an Eagle logo on it). |
I cannot say w/certainty what you have. There's an old trick that unscrupulous sellers will use: Grind/polish a wide "parting line" onto a cast crank to make it look like it's a forged crank that has been detailed by grinding down the wide parting line- a wide parting line that was never there in the first place!
So I'm w/you 100% on being skeptical until such time that it can be confirmed by someone who has intimate knowledge of this crank and its casting numbers. The following video shows the place to look for the parting line that will usually show it best- on the first throw back from the snout opposite of the counterweight. The cranks shown are SBC so will look different than yours but the concept still applies. That said, aftermarket forged cranks may show very little of anything at the parting line, depending on the manufacturing and processing and I should have probably mentioned this in my first post. The crank shown below is a 4" stroke Eagle 4140 forging w/their ESP finishing process applied. As you can see there's basically nada there to ID it: ![]() BTW, the ringing of a cast vs. forged crank he's doing in the video is all well and good IF you have cast and forged cranks, identical except for material, to compare. Otherwise it's a bit iffy to ring a crank and say 100%- "This is cast/forged". VIDEO- http://www.youtube.com/watch?v=8dA1AH5j9v8 BTW, Summit has sold various cranks under the Summit name that originated w/various well known manufacturers and Eagle is among them. On these cranks sometimes the ID was left intact but in other cases the ID was removed. You might have one of these, or a similar deal. Was the ID that was removed located on the side of the first counterweight, like can just be seen in the photo of the 4" crank above? Last edited by cobalt327; 12-13-2011 at 02:43 PM. |
The area that looks like a removed logo is on the rearmost throw, on the side of it. The front two throws have been rounded but I don't see anywhere a logo would have been removed. I can get it to ring like both of the cranks in the video, depending on how hard I hit it So yeah, not much help there. It has a fairly bright sound to it.
If what I've arrowed below is a parting line, that's a pretty good indication it's a forging.
So that's good news I guess. Now I just need to identify the manufacturer and the imbalance! Or at a minimum the imbalance. |
You'll be balancing it, I'm guessing. It will be apparent then what it wants. I know that doesn't help NOW when you're still collecting parts for the build. Last edited by cobalt327; 12-13-2011 at 04:26 PM. |
It does indicate "complete engine" and "less pressure plate" on the sheet. Total bobweight is 1691g. It came with the original 28oz parts in a box but i have no way of knowing if it was balanced with that stuff. I don't want to throw on 28oz stuff only to have it vibrate itself to pieces. Also, what tells you that it's a 1 pc RMS crank? |
I still have no clue what I have though. I guess I'm going to have to take it to a balancer to verify what balance factor is to be used.
| Ford 428 Crank in a 390 Block? | EliminatorXR7 | Engine | 4 | 02-26-2011 05:12 PM |
| ford crank id problem | john-dickjr | Engine | 6 | 03-30-2010 07:50 PM |
| Ford 393 stroker crank | SouthernRascal39 | Engine | 3 | 11-12-2009 07:31 AM |
| 3.8 ford crank counterwieghts | Haulin327 | Engine | 0 | 01-15-2008 11:37 AM |
| 36 Ford P/U Crank out Windshield | yeatman | Body - Exterior | 1 | 05-26-2007 02:16 PM |
