ford 347 stroker stalls at biginning of acceleration - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-06-2010, 01:07 PM
anyone out there had this problem? this is a brand new engine from ford motorsports with a holly ultra 650 cfm carb and a single plane vitor jr manafold......any ideas?
Old 08-06-2010, 01:20 PM
DoubleVision's Avatar
Have you checked the carbs pump shot? The very instant you move the throttle you should see 2 solid streams of fuel shoot out. Sometimes if the pump is bad or the pump cam is in the wrong slot it won`t give a immidiate pump shot which causes a dead spot.
Old 08-06-2010, 02:08 PM
I have had this problem before. It could be several things but I will hit what is common first. First, check the carb as mentioned above and you may need to make an adjustment to the accelerator pump to add more gas as the accelerator is moved from idle to acceleration. Secondly, check the timing to make sure it is not too retarded. This will cause the engine to drag or die out. Next, make sure you wires are routed to the correct cylinder. A 347 stroker may have a cam for a 351w which has a different firing order. I have done this and actually got the engine to run but not well as you are not running on all cylinders. Lastly, for certain cams you will need to up the stall speed on the torque converter. You can check the cam specs on the web and see what it recommends. Good luck.
Estimated Ford 347 Building Costs nightrain_rod Engine 0 06-24-2003 12:41 AM
Ford 347 Build-Up nightrain_rod Hotrodders' Lounge 4 06-23-2003 11:46 PM
347 Stroker nightrain_rod Engine 2 05-18-2003 06:40 PM
Whatever happend to these guys? hot_rod_kid Hotrodders' Lounge 20 12-17-2002 09:20 AM
1997 Ford Thunderchicken....engine stalls... BillyBob1950 Engine 7 12-12-2002 06:32 PM
