ford 351 cam in a 302 - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-30-2006, 05:57 AM
I was told recently that I coud put the camshaft (stock) from my 351 Ford
in my 302 for preformance improvmence. If so, do any of you have instalation advice or special requirments?
Old 05-30-2006, 06:32 AM
woodz428's Avatar
Troll Hunter
First, I'd check the cam specs. The 351W had a little more aggresive pattern, but I'm not sure the increase would justify the work. The main difference is to remember that all 351Ws had a different firing order than the early 302 so will need changed. It is the same as a late 5.0 engine which changed to the 351W style firing order in the early 80s.
Old 05-30-2006, 06:41 AM
brainsboy's Avatar
brains
It's a waste of time.
For 49$ you can buy a nice performance cam from summit. I really like the sum-3602.
Old 05-30-2006, 06:53 AM
351 cam in 302
thanks for the pointers. It is no extra work, since i am rebuilldilg both engines . i am going to sell the 02
Old 05-30-2006, 11:37 AM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Incorrect. 5.0s have the same 302 firing order through 90. Only the HOs and last few made in Explorers had the W firing order.
Which heads should I use on 302 Ford? Coleman396 Engine 8 11-08-2008 01:29 PM
Why is the Ford 302 block better than the 351W? BarbWire Engine 63 06-01-2006 05:35 PM
Ford 351 flexplate on Ford 289 1931 steve Engine 6 11-06-2005 11:52 PM
Ford 5.0, 302, 351W Performance Info xntrik Engine 10 09-06-2005 11:01 PM
Heads for Ford 302 Coleman396 Engine 12 03-31-2004 08:51 PM
