Ford 351 W- crank and rod clearances - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-25-2007, 09:20 PM
driveability's Avatar
Last journal entry: 930 4 speed transmission
I'm helping a friend rebuild his engine a 351 W, well after getting some parts back from the machine shop we installed the cam, crank and pistons. I see a problem with the clearances between the two rod ends that share a spot on the crank. The side to side clearances. We have one that feel normal, (Chevy guy here) and one thats down right tight, (.001/2) ?? and two that are less than expected.. I can't find a Clarence specification. I know there is a problem here but would like to have a specification to hit the machine shop over the head with.. I did check a few rod caps for thickness and they were equal as far as that goes. This is a budget job and is filling my garage, I would like to get it settled and right for a good friend..
Old 05-26-2007, 07:00 AM
Barry.M's Avatar
Old Phart
Last wiki edit: How to identify a Ford V8
Last journal entry: 27 T Roadster project: Underway cont.
Wiki Edits: 3
On 351C's the side to side rod clearances are .012" to .023" thou. Maximum. Never built up a Windsor so don't have any manuals on them.......sorry.
Old 05-26-2007, 09:33 AM
thanks,
I did find some specs .010 to .020, and I know this engine has a big problem and would fry fast if we don't get it right. My concern is one pair of rods is within specifications and the other 3 pairs are too tight. this is a mess!!!
stroke to rod ratio jacobm99 Engine 17 09-16-2010 10:06 AM
383 vs 350 TheCiscoKid Engine 86 05-03-2008 03:10 PM
327 in 88 Truck pete379 Engine 101 01-19-2006 09:03 PM
Rod ratio RobbieRat Engine 16 11-29-2005 06:52 PM
longest rods in std deck 454 bbc?? deuce_454 Engine 11 01-30-2004 10:06 AM
