Ford 351 windsor problem
I have 1977 ford f100 custom with a 351w. My engine will start up fine and will idle fine but when i put it in any gear it just shuts off. Also the engine will only idle with the hose off the pvc valve, when connected it will just turn off as well. Does anyone know what could be wrong?
If it still has an EGR, it may have corroded through allowing a massive air/vacuum leak.
If it's a new problem, then air/vacuum lines are suspect. Mechanically - timing as in a timing chain/gear that has worn to the point of way out or even jumped a tooth or so. Intake valve burned - a '77 351W had really mediocre heads at the best of times. Carb - is it flooding and only additional air (oxygen) will keep the mixture at a burnable ratio. You haven't given us much to go on, i.e., engine age (is it the OEM?), miles on it, compression check, vacuum readings, spark plug color, dist cap and rotor vintage(this is an early Duraspark ignition and not the best if OEM), dist shaft wobble. |
| Ford 351 W- crank and rod clearances | driveability | Engine | 2 | 05-26-2007 09:33 AM |
| Transfer case - NP 203 - 205 | jrm123180 | Transmission - Rearend | 2 | 03-24-2006 07:36 AM |
| 351 windsor in a 49 ford | jaxhome | Engine | 3 | 03-30-2005 06:24 AM |
| Ford 351 | 37fordslantback | Engine | 3 | 04-25-2004 01:57 PM |
| 351 Best all around Ford Performance Motor? | lakecityg | Engine | 28 | 07-25-2003 09:30 AM |
