Ford 351C valvetrain question
Does anybody know if I can swap in a set of 429 valves, springs retainers and keepers onto a 351C two barrel engine. I noticed that the 429 and 351C both use 11/32 stems and the four barrel 351C engine valves interchange with 429CJ valves. The reason I ask is.....the 429 has a 2.08 intake valve and a the 351C two barrel head has a 2.04 intake valve. The 429 uses a single lock keeper and the 351C uses a multi-groove keeper. The exhaust valves on the 429 and 351C two barrel head have the same diameter but the 429 uses the superior single lock keeper. Post 72 429's and 460's use a sled fulcrum rocker as does the 351C two barrel engine. So will it work, using 429-460 valvetrain in a 351C?
Thanks woodz428, one other question is will the 429 rocker arms work on my 351C and are the 429-460 sled fulcrums any better than the 351C rockers? I am just trying to do a budget rebuild on my 351C that will be going into my 73 Mustang that has a 302 currently.
| Ford Steel Wheel Tech | wheelkid | General Rodding Tech | 9 | 01-07-2007 06:31 PM |
| ford truck question | william r plise | Body - Exterior | 3 | 05-11-2006 05:38 PM |
| ford 351C aussie heads? | bob myers | Engine | 5 | 01-09-2006 10:15 PM |
| question for all you ford suspension guys | Blag | Suspension - Brakes - Steering | 7 | 03-29-2005 11:59 PM |
| Ford 302 Engine Question | Thuggishruggish3000 | Engine | 13 | 03-11-2004 12:22 PM |
