Ford 351W - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-04-2006, 08:43 AM
McF McF is offline
Ford 351W
1979 Ford 351W...
ran fine, shut off, cranked back up in am, barely runs. 4 cylinders at best. Every now and then backfires through carb. Seems like timing off bad but doesn't make sense that the timing chain would've skipped a tooth at this point, not ruling that out though.
Tested coil, pickup, etc. to eliminate Duraspark ignition problem.
Any suggestions?
Old 03-04-2006, 01:11 PM
Max Keith's Avatar
rough running
Sounds like a possibility of one or two things or both.
How old is the gas you are running?
Did you rebuild the carb?
Could be one or the other or both being the culprits.
Old 03-05-2006, 10:05 AM
McF McF is offline
Nothing has been touched previous to failure. Plan on pulling valve covers to see if all is working correctly.
Old 03-05-2006, 05:24 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Does your engine have a TFI module on it, and if so, did you have it tested? Also does it use a Crank Position sensor for PIP information..79 was kind of a some did, some didn't year..as far as I can tell, and I am not a Ford guy at all..
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Ford vs Chevy question savman1 Engine 31 10-14-2008 07:13 PM
Explorer Disc Bbrakes on a 9" Ford Rear End Mustangsaly Suspension - Brakes - Steering 2 10-31-2005 04:18 PM
Wanna Talk Cars "Fords" 66Falcon Hotrodders' Lounge 17 10-01-2005 05:29 AM
Ford 5.0, 302, 351W Performance Info xntrik Engine 10 09-06-2005 11:01 PM
T-5 transmission codes needed xntrik Transmission - Rearend 4 09-06-2005 09:09 PM
