Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ford 351W distributor
Old 05-24-2012, 12:40 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by Custom10
If it really is a mud play thing then just this once I say,,,lock it all out, no vac advance. Have it timed at 18, mark dist to block or use a stop. Then time it at 35, mark dist or block. Set it on kill for the mud blast and back to stun for the way back to home or the trailer,,,trailer that is were you find most of these ford play things
ok fly the mail boys
Hmm maybe there is a way change timing with variable voltage on this fancy blue oval distributor rather than twisting it.
The white wire is a timing retard, there might be a way to use it to start and/or use to drive home from the bogs if the timing is locked out, or if the initial timing was too much for the starter to crank the engine hot.
There's a couple links, wiring diagrams etc. here I threw together earlier (until I can research it better, and/or someone else adds more to the page ) that may be of some use.
