Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ford 360 vs 460
Thread: Ford 360 vs 460
  #17 (permalink)
Old 02-21-2008, 07:43 PM
68novafan's Avatar
68novafan 68novafan is offline
Ford Fan At Heart
well i killed the 460 idead ( no longer available). what can i do to wake up the 360 a little bit? it has good compression and is otherwise a good motor. im running everything stock right now. it has a 2 barrel intake. anyone know of any good 4 barrel combos for this that wount brake the bank? the crb on it right now need gone over over replaced so i would like to upgrade things as i replace them. Also going to pop in a new timing chain. From what i understand stock the cam is retarded/advanced? what kind of timing set should i install. any help would be great but im running kinda low budget.
thanks
