Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ford 360 vs 460
Thread: Ford 360 vs 460
  #18 (permalink)
Old 02-21-2008, 08:47 PM
carsavvycook's Avatar
carsavvycook carsavvycook is offline
My 2 cents worth
Wiki Edits: 3
Originally Posted by 68novafan
well i killed the 460 idead ( no longer available). what can i do to wake up the 360 a little bit? it has good compression and is otherwise a good motor. im running everything stock right now. it has a 2 barrel intake. anyone know of any good 4 barrel combos for this that wount brake the bank? the crb on it right now need gone over over replaced so i would like to upgrade things as i replace them. Also going to pop in a new timing chain. From what i understand stock the cam is retarded/advanced? what kind of timing set should i install. any help would be great but im running kinda low budget.
thanks
A good 4bl manifold with a power range from idle to 5500RPM is Edelbrock 2105, it is a dual plane manifold. I would use a 600CFM carb with it. Edelbrock also has a double roller timing chain set #7808. Price em around you should be able to get all three under $650.00's.
Personally I would change the cam and lifters also.
