Ford 390/C6 Torque Converter question - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-21-2012, 06:04 PM
Need some help here guys. I asked 3 different people and got 3 different answers. I will post my cars specs below and see what ya'll think
-1969 Ford 390 block, Improved Performance.
-Holley 750 Vacuum Secondary carb
-Ported Edelbrock Streetmaster Intake
-Ported and Polished C8AE-H heads, Hardened valve seats, new valves, new springs
-Comp 270H Cam w/ matching lifters
-Dual Roller timing chain
-GM HEI Distributer w/ ACCEL 8mm wires and new plugs
-Full Length Custom Headers
C6 transmission has custom valve body, shift kit, E4OD Gears and with extra clutches.
3.10:1 Rear End Ratio
People are telling me I need a Stock Stall, 2000 stall (which I find is about stock), and one guy said 3000 stall.
This is not going to be a racer, just a Sunday driver. Any suggestions on which torque converter to use? All my gear (cam, intake, carb, etc) is pointing to stock converter size.
Old 12-22-2012, 12:11 AM
JeffB's Avatar
2400-2600 stall just enough to prevent creeping at a stop and work with the rest of your combo,a transmission cooler addition is also a good investment.
Old 12-22-2012, 06:59 AM
Irelands child's Avatar
This sounds about right to me as well.
FWIW - a DD/weekend driver doesn't need a high stall converter with even a TCI Saturday Night Special type being just fine though the TCI Breakaway closer. Jegs has a decent chart of what to expect with cam and rear gears shown: TCI Saturday Night Special Torque Converters - JEGS
TCI is now part of Comp Cams (which seems to have doubled the prices), so possibly a call to their tech dept might be a good idea too
Another Torque Converter Question 68Birdman2 Transmission - Rearend 4 10-28-2009 11:25 AM
torque converter question 440a-body Transmission - Rearend 1 09-04-2009 11:07 PM
ford c-6 torque converter problem 39buickstreetrod Transmission - Rearend 8 12-18-2007 01:43 PM
Torque Converter Question leejoy Transmission - Rearend 5 10-02-2006 11:57 AM
Torque converter question. gavinpierce Hotrodding Basics 1 02-15-2006 09:53 AM
