ford 390 fe backfire at startup - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-27-2013, 03:44 PM
62galaxiguy's Avatar
ive got a ford fe 390 that backfires when starting up.it has a crane rv cam holley 1850 600 cfm carb long tube headers and 9.5 to 1 pistons it was rebuilt 5 yrs ago.problem started after tossing the draft tube and putting in a pcv system in place of the draft tube.When it runs ive got 20hg of vacuum at thebaseplate vac connection.timing is 10 btdc.It alsdo has a pertronix ignition.
Old 01-27-2013, 04:24 PM
painted jester's Avatar
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
Check your choke setting? Whats your climate? And elevation?
Jester
Old 01-27-2013, 04:47 PM
its a manual choke
50 degrees at 500 ft asl
Old 01-27-2013, 05:09 PM
are you picking up your vacuum at the base of the carb PCV port? if your getting your vacuum from an intake runner it will lean out a cylinder and backfire or pop through the carb.
Like F.Bird says you must have a breather to aid the pcv in evacuating the crank case!
Jester
Old 01-27-2013, 07:07 PM
pcv hose goes to
carb base gets full manifold vacuum.Dizzy gets ported vacuum from holley cab vacport.Oil filler cap has a breather .This is a stocksetup.
Old 01-27-2013, 07:16 PM
Sorry I left out 2 words that are needed in that post (the P.C.V.) Below is how I meant it!!!!! sorry again LOL age is crowding out my proof reading ability LOL Give this old fart a break!!! LOL
if your getting your vacuum for >the P.C.V.< from an intake runner it will lean out a cylinder and backfire or pop through the carb.
Jester
Old 01-28-2013, 01:11 AM
JeffB's Avatar
Try changing the Holley's power valve from a 6.5 (stock) to an 8.5 power valve.
backfire at startup, now misses under load blue400 Engine 8 09-09-2013 08:04 PM
390 ford rollenhard Hotrodding Basics 12 01-27-2013 08:14 AM
Ford 390 BIGBLOCKFORDMAN Hotrodding Basics 2 11-06-2011 07:50 AM
Help with ford 302 miss and backfire Phoneguy Engine 14 12-28-2010 03:57 AM
Ford 390 CustomFord Engine 16 02-09-2008 01:20 PM
