Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ford 390 timing
Thread: Ford 390 timing
Old 10-13-2008, 02:46 PM
454C10 454C10 is offline
try this.
Set it at 6 degrees (without the vacuum advance), then connect the vacuum advance so it works at idle. should have around 26 at idle. That will increase the idle speed to where you need it. The vacuum advance will fall off when the manifold pressure drops.
