Ford 393 stroker crank - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-11-2009, 03:23 PM
SouthernRascal39's Avatar
SouthernRascal39
Hey Everyone,
Iím just wondering, I have a 1969 351 W which has the shorter deck height, can a 393 stroker crank be dropped in without having to make clearance in the block. A standard stroke for a 351 is 3.5 and the 393 crank is 3.85. My motor is already built it is just a 351 .030 over. KB hyper pistons and alum heads. The cam is a comp cam 270H .500 lift intake and exh. Edelbrock RPM intake and a holley 750 carb. ARP bolts used throughout the whole motor. The deck was skimed for straightness nothing major. So like I asked, can the 393 stroker crank drop in with no other changes? Thanks for your help ahead of time.
Thanks
Craig
Old 11-11-2009, 08:28 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Think about it, if the motor is zero decked, the piston's are going to be raised .35 in the bore. You'll need pistons made for whatever length rods you're using, more likely than not the block will need clearancing, and possibly a small base circle cam. That's all just stroker sense, I'm not a Ford guy, someone will pop on here sooner or later and give you some Ford specific info I'm sure.
Semper Fi
Old 11-12-2009, 06:26 AM
SouthernRascal39
393 stroker crank
Thanks for your reply, I know that for this stroker setup, this is the only one that ford has that uses the stock rod length. Thats why i was wondering if it would drop right in. I know with most stroker applications, modifications are needed in the block to clear the crank.
Old 11-12-2009, 07:31 AM
onebadmerc's Avatar
I need a bucket of arc sparks
The 393 stroker uses a special crank, 351W rods and 302 pistons. So if you have 351W pistons on your rods and slap in the 393 crank the pistons will be out of the block. You will also have to do some clearance work at the bottom of the block. I don't remember who makes it but there is a template you can buy for doing this.
50 Ford F1 w Monte Carlo Clip joe123 Suspension - Brakes - Steering 5 05-26-2008 05:48 AM
Wanted 393 stroker parts. heads, manifold Kurtgro Engine 0 06-09-2007 08:22 AM
forged crank question Ratoflic Engine 2 04-18-2006 04:50 AM
Wanna Talk Cars "Fords" 66Falcon Hotrodders' Lounge 17 10-01-2005 05:29 AM
ford 347 stroker motor question??? inkfixer73 Engine 1 10-02-2003 10:47 AM
