Ford 4.9L 300ci Straight-Six - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-23-2007, 02:48 PM
I recently bought a 95 F-150 with the 4.9L EFI engine. I love the engine but i want more grunt from it. Can anyone tell me anything about beefing it up for a relatively small price tag. I've heard of putting 5.0L fuel injectors works well, but what else should be done with it to make it work correctly?
Thanks for any posts!
Old 05-23-2007, 02:57 PM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
Hey WCChopper-
I went to WCC before in Ann Arbor. Used to live in michigan.
I'm sure the 4.9 responds to upgrades like any other internal combustion engine. By grunt, do you mean towing capability/torque? I think that might be a reasonable goal. If you're talking about high-end power that's probably limited by your head/valving which is probably a tall order.
Injectors alone are not likely to help, and I think they are costly. A 5.0 injector is actually responsible for injecting less fuel per revolution than a 4.9 injector. First thing for a low-budget upgrade would actually be gearing. Is this a 2wd truck? You may be able to swap a rear end from another truck in there for less than 200 bucks and feel a significant increase in pull. Much more than if you did a cam/exhaust upgrade.
Good luck
K
Old 05-23-2007, 04:12 PM
Wiki Edits: 31
www.fordsix.com start there, those guys know there stuff when it comes to Ford 6's, not to mention the guy that runs the forum, also runs Classic Inlines, the best place for Ford 6 parts. but TURBOCHARGER and larger injectors come to mind. stock EEC-IV can be tuned with piggy back controller, to handle the engine change.
Old 05-23-2007, 05:01 PM
Yeah it is a 2wd with a 3.08 rear setup. Ill look into getting a different rear, i know ford put a 3.43 or something around there out for it. how much would a locker look at setting me back?
Thanks for the reply!
Old 06-10-2008, 05:33 PM
voeter
If your still looking, 5.0 injectors and 5.0 throttle body will do wonders. Also open up the exhaust to a 3'' from the engine through the cat and out the back.
Old 01-29-2010, 11:07 AM
1993 Ford F150 4.9 4x4
I have a 1993 Ford F150 4.9 4x4. I want to give it more power really and i was wondering how to do this? could anyone help thanks
Ford Inline 6 4.9L with only 145 hp? GnrYmr Engine 13 12-02-2009 11:06 AM
Ford vs Chevy question savman1 Engine 31 10-14-2008 07:13 PM
Ford Muscle..what's wrong with them? tm454 Hotrodders' Lounge 41 11-20-2006 12:37 PM
Explorer Disc Bbrakes on a 9" Ford Rear End Mustangsaly Suspension - Brakes - Steering 2 10-31-2005 04:18 PM
Wanna Talk Cars "Fords" 66Falcon Hotrodders' Lounge 17 10-01-2005 05:29 AM
