Ford 4 speed identification - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-24-2007, 07:26 PM
I used to own an 1980's Bronco 6 cyl that had a 4 speed with the 4th gear that seemed to be more like a freeway overdrive gear. A buddy of mine had the same trans in his late 80's early 90's f 100 6 cyl.
Can anyone tell me what transmission this was and which years I might be able to find one in at a wrecking yard?
Next up, will this trans bolt up to a Ford Y engine bell housing? If yes, what else might I need to do to make it work in my 1960 F 100?
Thanks to all,
29guy
Old 12-24-2007, 07:33 PM
Brian_B's Avatar
Lost in the 50s!
Last journal entry: time to start body work
I don't think any modern transmission will bolt to a Y-block. Not directly anyway. Mummerts has adapters for the C4 and the T5, but they cost.
http://ford-y-block.com/
Go there and scroll down. They have about everything for the Y-blocks.
My 56 has the original 3 speed. Non-syncro 1st and all. It has a 1:1 final ratio. My dana (timken) 44 rear axle has a 3.73 gear.
I will eventually swap to a 9" (which you should alread have) and go with a higher gear ratio (numerically lower) for the highways. The one I am getting currently has a 3.50 set, but they are not too hard to swap if needed.
Ford Muscle..what's wrong with them? tm454 Hotrodders' Lounge 41 11-20-2006 12:37 PM
ford C4 conversion to a 4/5 speed automatic with lock up andreas 67 Transmission - Rearend 13 11-09-2005 02:24 AM
ford I4 engine identification morax2001 Engine 1 06-07-2004 05:36 PM
ford 2 speed? Jared Transmission - Rearend 1 05-09-2004 04:31 AM
Whatever happend to these guys? hot_rod_kid Hotrodders' Lounge 20 12-17-2002 09:20 AM
