Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ford 400 Dished to Flat Top Pistons = Rebalance Crank?
Old 03-21-2010, 10:09 PM
stroker_SS stroker_SS is offline
Everything is HAMMER!
You may be able to find pistons of the same weight as those that are in your engine in which case no rebalancing would be necessary, although many will recommend it.
Are you going to be doing any other modifications to this engine while it is out of your vehicle being machined the new pistons?
Although not necessary having the rods resized and new rod bolts installed(I like arp's) is really worth it.
What kind of budget are you working with?
