Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ford 400 Dished to Flat Top Pistons = Rebalance Crank?
Old 03-22-2010, 02:01 PM
My79Ford400ciF1504x4's Avatar
My79Ford400ciF1504x4 My79Ford400ciF1504x4 is offline
OK, so for the most part when i buy a set i should look for some that are balanced with my other ones, but if not then its not a big deal as i understand, correct?
Anyway as for the improvements that i am going with is: New cam, timing gears and spring set, 351c 2v open chamber heads (already have these), a set of head studs, guide plates, and rockers. And then a rebuilt kit with bushings and gaskets and stuff. So i just figured if i was in that far then i would raise my compression some more. Any other tips? Im trying to keep the budget low so im not planning on having anything special or custom made or anything.
