Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ford 400 Dished to Flat Top Pistons = Rebalance Crank?
Old 03-22-2010, 01:27 PM
ericnova72's Avatar
ericnova72 ericnova72 is offline
More for Less Racer
If you are going to keep it under 6000 rpm I wouldn't worry about the balancing one bit. No reason to use the 351C 2v heads either, they are no different than the M heads you have now, exactly the same open chamber casting.
