Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ford 400 Dished to Flat Top Pistons = Rebalance Crank?
Old 03-22-2010, 08:28 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by My79Ford400ciF1504x4
Any suggestions as to where i should buy them from? I know that there are only a few places. The cam set that I have picked out is one that is 800 to 4800 rpm, its going into a truck.
AFA where to get the pistons, etc. from- I'd probably at least look at Competition Products, Northern Auto, Summit and Jegs to see who had a better deal.
You might get lucky and get them to tell you what the pistons weigh so you can do a comparison.
Try to see if you can use the head gasket thickness to get the quench around 0.040". If you get it around that figure, it will tolerate CR and/or less octane better.
It sounds like you got it pretty well sorted out.
Good luck!
