ford 400m 2v or 4v?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-26-2010, 06:18 PM
Does anyone know what would be a better fit on my 78 ford 400m a 2v carb or 4v? My truck is low geared so MPG is alittle bit of a concern. However I've been told that 4v might actually save you on MPG. This truck is just a DD. Thanks for the reply
Old 10-26-2010, 08:25 PM
mud.man.rj's Avatar
Carb and mileage
A 4brl will get better gas mileage if you stay out of the secondarys due to the primarys being smaller than your 2only on a 2brl, but punch er open and the fun begins but the gas station gets closer.
Old 10-27-2010, 01:45 AM
the ems guy
stick with the 2bbl, not worth the money. if all you want is mpg then better to chnage trans to overdrive. but in he long run it is hard to get a payback unless you drive a lot.
Old 10-27-2010, 07:08 AM
Hello
Well the first question.
Are you going to purchase a new intake?
Edelbrock makes both 2 & 4bbl. allu. intakes for the 400
Is this an automatic or manual?
What gear do you have now?
Old 10-27-2010, 07:21 AM
If I purchased the 4v I was just going to put an adapter on my 2bbl intake for now. my truck is a 4spd manual. Thanks for the help so far
Old 10-27-2010, 07:36 AM
400 4v
don't go the 4v, some time ago i converted,mine millage was terrible,power great, so with todays fuel costs no.Used a edlebrock ALU int and Holley carb,shadbolt reground rv cam. went well. cliff
Old 10-27-2010, 08:02 AM
Hello
Don't use the adapter!!
What carb do you have? 2150 ford?
What's the bore size. It's on the fuel bowl. (drivers side in a circle)
1.21 or 1.23 ??
Old 10-27-2010, 08:44 AM
It's a 2bbl motorcrap 1.21. Not sure what kinda CFM it puts out.
Old 10-27-2010, 09:05 AM
Hi
The 1.21 is a 350cfm carb.
Prob. 1 of best 2bbl. out there. I run a 1.23 on my 351W circle track car.
They are easy to rebuild & set. They have a power valve like the Holley.
You only have to take off the top to change jets.
Choke can be manual or electric.( I don't have 1 - lol )
Old 10-27-2010, 12:21 PM
the ems guy
400m
this is a holley carb 2bbl identical replacement for for ford and it is a500cfm and can come with all ford linkage hook ups i have one on my 351
Old 10-27-2010, 04:22 PM
mud.man.rj's Avatar
Junk 2brl
I just put an Edelbrock performer intake(used-CHEAP-price) and a 625 cfm Edlbrock carb on a 77F250 w a 400 and it never performed so good and the mileage went up substanially. Telling you good choice, truck really kicks now.
Ford vs Chevy question savman1 Engine 31 10-14-2008 07:13 PM
Ford Muscle..what's wrong with them? tm454 Hotrodders' Lounge 41 11-20-2006 12:37 PM
Explorer Disc Bbrakes on a 9" Ford Rear End Mustangsaly Suspension - Brakes - Steering 2 10-31-2005 04:18 PM
Anyone here runnin with a 4v 4.6 ford motor? Mrwilson Engine 3 10-24-2005 09:00 PM
2v to 4v fordracing Engine 2 02-14-2003 03:03 AM
