Start a tech article on any subject...
...hundreds of hotrodders help build it into a comprehensive resource.
Fresh wiki articles that you can add to: Air suspension on a front solid axle, Basic stuff for newbies, Building a new shop, Ceramic insulation, Electric fuel pump mount, Engine and transmission mounts, Freeing a stuck engine, Gasser, How to check driveline angle, How to make a vacuum power brake bleeder, How to safely cut steel with a torch, Improving fuel economy, Narrowing a rearend, Patching a body panel, Quick-disconnect rear mount battery, Reducing vehicle weight, Stereo installation, Stripping paint, Valve spring setup, and many more...
Or, start a new article.
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 05-14-2002, 01:37 PM
Dennis Dennis is offline
Post Ford 400m engines
I have a 32 Harwood car that I bought unfinished that has a Ford .030 over 400M in it. I am not familiar with anything but small block Fords (Windsors). Is this big Cleveland a good choice for a torqer motor for a 2200 # street rod or is it just a Queer duck?
Old 05-14-2002, 01:46 PM
KULTULZ's Avatar
KULTULZ KULTULZ is offline
aka Duke of URL
 KULTULZ's barnstar
Thumbs up re: Ford 400m engines
[quote]Is this big Cleveland a good choice for a torqer motor for a 2200 # street rod<hr></blockquote>
Yes, it is definitely a torquer motor.
Modifications are the same as the 351C, except the 351M/400 has a taller deck height..
[ May 14, 2002: Message edited by: KULTULZ ]</p>
Old 05-15-2002, 09:49 AM
wellcontrol wellcontrol is offline
Post re: Ford 400m engines
I already left a post about the 400m before.
The 400m is basically a 351c with a bigger
stroke,but was way more reliable.When they got
rid of 390's in trucks they replaced them with
the 400m.These engines were considered wheezers
cuz they only made about 165 hp,but they had tons
of torque.We built one in a 1978 ltd thet whooped
up on local mustangs(in the early 90's).
Hot Rod had a good story on how to build basically
400 hp/400+lbs. foot of torque out of these
babies.check it out.
Old 05-18-2002, 08:30 AM
[quote]Originally posted by wellcontrol:
<strong>I already left a post about the 400m before.
babies.check it out.</strong><hr></blockquote>
Old 01-12-2003, 01:23 PM
B1boozer71 B1boozer71 is offline
Exclamation re: Ford 400m engines
[ January 12, 2003: Message edited by: B1boozer71 ]</p>
Old 01-12-2003, 01:29 PM
The 400M has a 1 inch taller deck height than the Cleveland and it has the big block transmission bolt pattern. I have 3 of these engines with C6 transmissions. 2 are in a '73 Ranchero 500 and a '74 Ranchero GT. Both of these cars scratch in second even when not getting on it. These are really strong engines and both are factory, get excellent mileage and power with a 2 barrel carb
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
