Ford 428 FE smoking....#1 cylinder only - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 09-19-2008, 06:39 PM
Wiki Edits: 27
was the headgasket on right
The dealer worked on my 63 fastback just before i bought it in 64, he original owner got drafted and couldn't make the payments on army pay so I got just take over loanI. the headgasket was on backwards so water only circulated in the front of the engine. over heating etc...I pulled the 390 and put in a 3522 then sold the car and put the 3 carb engine in my roadster.
  #32 (permalink)
Old 09-19-2008, 08:25 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
I was wondering how long it would take for someone to mention a backwards head gasket. The large open water ports ussually go to the rear.
  #33 (permalink)
Old 09-20-2008, 05:26 AM
I checked the rod bearings and they have the oil squirter notch. I also double-checked the head gaskets when I took them off. They were both installed correctly.
I strongly suspect my ignition timing was the trouble, however a slight manifold leak along the left front may have something to do with it as mentioned previously. All I can do is be very carfeful in the re-build and watch for those things.
So far, pistons are a problem. I had this engine balanced and the piston weights were 597 grams. So far, all I can find are much lighter pistons...around 520 grams. Not sure if that will significantly upset the engine balance or not. Howver, I am still waiting on some custom companies to respond to my request for quote.
428 heads for a 390 Fe Crazy_John69 Engine 9 11-08-2011 06:21 PM
Vintage Ford FE Exhaust manifolds Bill Riese Engine 2 08-27-2007 09:18 PM
Will Ford 460 Billet HEI Distributor fit a 390 FE?? texastomeh Electrical 4 07-09-2007 07:52 AM
428 Ford Builder 47fordhotrod Engine 4 06-01-2002 03:21 PM
For Sale Ford builder 428 47fordhotrod Engine 2 05-31-2002 02:55 PM
