Ford 460 - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-11-2012, 12:17 PM
Ford 460
Hi out there can anyone tell me when i take the vaccum line off the distributer on my 1971 460 mark111 Lyncoln wy there is no vaccum thankyou miggs
Old 08-11-2012, 01:41 PM
LATECH's Avatar
Could be hooked to ported vacuum. It also could have several thermo vacuum controls and such that are defective , or just blocking vacuum at the time you checked.
Post a shot of your engine. That will help.
Fact is stranger than Fiction
Old 08-12-2012, 05:04 PM
ford 460
Thanks Latech for the information i dont know if i can get a picture i"m not good at that thanks again Miggs
Old 08-12-2012, 05:21 PM
Irelands child's Avatar
A Ford OEM distributor is "always" connected to the ported vacuum connection on the carb. It's below the throttle plates where you should never have any noticeable vacuum. GM cars are usually full manifold vacuum - that is unless they are using an MSD distributor which specifies a ported source.
Irelands child
Old 08-14-2012, 08:26 PM
ford vacuum
thankyou for the information on the for vacuum
Old 08-14-2012, 09:22 PM
RWENUTS's Avatar
I run my 460 to manifold vacuum with 12* initial. Won't run worth a crap hooked to ported.
Ford 460 BB rbejaisingh Hotrodding Basics 6 09-20-2010 10:53 PM
Ford 460 Chevy 84 Engine 2 08-06-2010 08:05 AM
Ford Anglia / 460 Ford Help martin UK Introduce Yourself 1 12-19-2006 01:19 PM
Need some info on 460 Ford....... onebadmerc Engine 2 11-24-2006 10:49 PM
Ford 460 Yub350 Engine 8 10-30-2004 01:51 PM
