-   -   Ford 460 intake questions (http://www.hotrodders.com/forum/ford-460-intake-questions-225014.html)
rickpilgrim 10-14-2012 11:03 PM
I have a 86 460, freshly rebuilt with a Howards RV cam(213 degrees @ .050, .502 lift,111 lsa, 106 centerline) 2.19/1.88 valves bowl blended and port matched, 8.5/ 1 comp, HEI style ign, arp hardware but otherwise stock and will be used for towing.
On this tame of a motor is the Edelbrock performer better or the Wieland Stealth the way to go?
techinspector1 10-14-2012 11:36 PM
Best street manifolds below 6500 rpm's.....
Weiand 8012 - Weiand Stealth Intake Manifolds - Overview - SummitRacing.com
Edelbrock 7166 - Edelbrock Performer RPM Intake Manifolds - Overview - SummitRacing.com
Either design will begin pulling at around 1,500 rpm's and will give you better mid-range than the low-rise standard Performer in my opinion.
RadRidesByDan 10-15-2012 07:40 PM
I had the Weiand stealth on mine and it was great.....dual plain....kept the power band low where I needed it. Best bang for buck in my opinion
