Ford 460 intake questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-14-2012, 11:03 PM
I have a 86 460, freshly rebuilt with a Howards RV cam(213 degrees @ .050, .502 lift,111 lsa, 106 centerline) 2.19/1.88 valves bowl blended and port matched, 8.5/ 1 comp, HEI style ign, arp hardware but otherwise stock and will be used for towing.
On this tame of a motor is the Edelbrock performer better or the Wieland Stealth the way to go?
Old 10-14-2012, 11:36 PM
techinspector1's Avatar
Wiki Edits: 326
Best street manifolds below 6500 rpm's.....
Weiand 8012 - Weiand Stealth Intake Manifolds - Overview - SummitRacing.com
Edelbrock 7166 - Edelbrock Performer RPM Intake Manifolds - Overview - SummitRacing.com
Either design will begin pulling at around 1,500 rpm's and will give you better mid-range than the low-rise standard Performer in my opinion.
Old 10-15-2012, 07:40 PM
Last journal entry: front suspension build up
I had the Weiand stealth on mine and it was great.....dual plain....kept the power band low where I needed it. Best bang for buck in my opinion
Ford 460 holley 750 Questions :) lil-vulky Engine 16 10-18-2012 08:34 PM
Ford 460 ci carb questions HELP ME!! RampedUpMobile Engine 5 04-09-2010 10:20 AM
Ford 460 EFI Manifold Questions JdOwNj Engine 5 12-17-2008 06:18 PM
Ford 460 Questions 76 elco Engine 11 04-09-2008 03:49 PM
Ford 460 Intake Manifold Question Tired Ole Ford Hotrodding Basics 4 12-02-2006 01:00 PM
