Ford 460 low compression and rough idle - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-25-2012, 07:55 AM
I just got a F350 with a 460 with 160,000 miles. I'm told by the PO that it has low compression in two cylinders (# 1 and #5). It's not drivable, but it starts. I let it idle for about 10 minutes and I saw lots of gray smoke from the tail pipe and none from the oil fill hole.
This makes me think that the piston rings are bad, but the heads are good, is this a correct assumption?
Second; the rough idle could be a stretched timing chain, correct???
Also, can the timing chain be the cause and cure for low compression?
Thanks
Old 11-25-2012, 08:21 AM
vinniekq2's Avatar
do a cylinder leak down test. The rough idle is from running on 6 cylinders
Old 11-25-2012, 08:27 AM
Wiki Edits: 27
timing chain.
A bad timing chain would cause all the cylinders to be about equally low. there is some other problem also, You can check the timing chain by pulling the dist cap, watching the rotor and turning the crank pully with a wrench, then seeing how much rotation in the opposite direction before the rotor moves. and you get a few more ponies by using a double roller chain and setting the gears dead on , the smog 460's ran retard on the cam as a cheap way of emission reduction.
Old 11-25-2012, 09:03 AM
Time to buy a leak down tester......
I've rebuilt one engine before, an air cooled VW, worked out well, but I don't think I want to mess with this one. Ill probably buy a crate engine. They're in the range of about $1700. Not too bad.
I'm hoping it won't have to come to that and maybe I can get by with spending a few hundred instead of a couple grand.
So for now, a leak down and a compression test. I'll repost with results.
The other issue is probably really worn out piston rings???
Thanks
Old 11-25-2012, 09:26 AM
Wiki Edits: 27
spark plug fitting.
You can knock out the center of an old spark plug and weld an air fitting to it for a quick and dirty test.
Old 11-25-2012, 10:06 AM
That sounds good. The one's I've been looking at have gages, is that important? without a gage, I guess I would be able to go only with what I can hear?
Thanks
Old 11-25-2012, 10:32 AM
vinniekq2's Avatar
just rent/borrow a guage and you need a low pressure compressed air source
Old 11-25-2012, 11:40 AM
Just checked with Autozone. They have them in the "rent a tool".
Thanks
low vac rough idle baddme70 Engine 6 02-20-2012 05:19 PM
03 Ford Ranger 3.0 rough idle ???? paradox1 Engine 4 07-31-2011 05:30 PM
SBF 302 Rough idle/pedal=Battery low charge??? fittyfod Engine 3 04-03-2011 09:07 PM
460 Ford Pops!out exhaust on idle. moodier Engine 1 03-15-2006 04:02 PM
350 sudden rough low idle JohnnyGTO Engine 9 06-19-2004 06:52 PM
