Thanks! Thanks Top 5 Wiki Tech Article Editors! Thanks!
Updated 11/07/08
#1
Alittle1
169 edits
#2
Crashfarmer
161 edits
#3
Powerrodsmike
125 edits
#4
Techinspector1
112 edits
#5
Oldguy829
85 edits
Read and write hotrodding how-to articles on the Crankshaft Coalition Wiki. See 100+ articles, or read The 8-sentence guide.
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 02-23-2008, 06:46 AM
62galaxiguy's Avatar
62galaxiguy 62galaxiguy is offline
Ford 4r55e tranny problems
Ive got a 02 ford ranger w/3.0 v6 and my tranny o/d lite on the dash is flashing. The shop i took it too says it needs a rebuild! This truck has only 80k miles! Anyone have any idea if it could be something else. Thanks
Old 02-23-2008, 07:00 AM
Crosley's Avatar
Crosley Crosley is offline
Moderator guy
 Crosley's barnstar
re: Ford 4r55e tranny problems
the OD light flashes when a trouble code is present in the computer. Knowing what the codes are helps to ID the area of the trans that has problems.
A trouble code does not necessarily tell you the exact part that is bad, a trouble code is an indicator of the problem area.
Is the trans acting badly? Lost any of the forward gears or other wrong actions.
post back when you can.
Be kind to your children... some day they may be decide what nursing home to put you in
Old 02-23-2008, 07:13 AM
Have all gears but
When light starts flashing there seems to be a delayed upshift. Its fine at high speed (70mph) Thanks.
Old 02-23-2008, 11:10 AM
Chazmac Chazmac is offline
Moderator
Lots of problems with this trans. It is called a 5R55E/W. Ford redesigned the trans for the new Explorer chassis (yours) and introduced a wealth of new problems. The biggest trouble spot is the servo bores for the two bands the trans uses to upshift. Most commonly the overdrive bore wears allowing for significant slippage. Ironically, this slippage is not usually felt when driving until significant internal damage has occurred. The computer, on the other hand, is able to detect slippage and records codes indicating incorrect gear ratio, sometimes for several different gears. There is no easy or quick fix for these problems. A quality rebuild will include servo bore machining and rebushing along with other upgrades. Your trans shop should be able to detail these and explain their benefits. Ford does not address this issue and their rebuilts DO NOT have repaired srevo bores.
Old 02-24-2008, 03:25 PM
pmeisel's Avatar
pmeisel pmeisel is offline
Glad the Jeep is on the road
 pmeisel's barnstar
This tranny was originally designed for european use primarily -- small/light cars...
the additional load of heavier vehicles took its toll.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Ford 4r55e tranny problems"
!ford C4 tranny capacity! COUGARPOWER Hotrodding Basics 3 01-12-2006 10:12 PM
Wanna Talk Cars "Fords" 66Falcon Hotrodders' Lounge 17 10-01-2005 05:29 AM
88 AOD tranny problems rflud Transmission - Rearend 9 02-17-2003 04:53 PM
Ford auto tranny question??? cabrio Transmission - Rearend 1 01-30-2003 05:24 PM
64 Falcon tranny swap problems Halteclere Transmission - Rearend 5 12-15-2002 12:46 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
