Ford 4R70W - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-17-2011, 12:21 PM
cal1320's Avatar
Ford 4R70W
Wifes 02 F150 truck with 146 K miles has developed the typical torque converter shudder.
I've flushed the fluid (mercon V) and changed the filter. The pan had no metal on the magnet and no chunks in the bottom. I know 146K is a lot of miles but I have been advised by a repair shop owner to put in a new converter and go. He claims these transmissions are good to 300K if the pan was clean when dropped. This truck has never had a trailer on it so it has never seen any load.
Whats the consensus?
Buy a converter and install it myself or bite the bullet and get it rebuilt?
If the clutches are still good, what is the life of the electronics in these?
Old 02-17-2011, 06:01 PM
LATECH's Avatar
Just put a converter in it.If you do a lot of local and city driving it is most likely worn as with all the on -off slipping to engage puts plenty of wear on the clutches. It has cycled about a gadzillian times , probably wouldnt be such an issue if they were all highway miles.
They shouldnt have to completley remove the trans or seperate the exhaust to change it either so mention you heard that, maybe they can give you a price break.
Old 02-17-2011, 06:21 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
X2 you can flush it all you want but only one true fix and you already know what that is. Now i am not a believer in snake oil fix but I had one that started to shudder and i put some DrTranny in it fix it for about 6mos and that was it so that's not a fix either. Best replace it.
(There is nothing in the "BOTTLE" going to fix it).
Cole
Temporary fixes are just that "TEMPORARY"
Old 02-17-2011, 07:43 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Did you break open the trans filter? These trans pull alot of fluid in and debris can be sucked inside and the pan looks cleaner
Old 02-18-2011, 07:39 AM
cal1320's Avatar
Thanks guys. We'll probably only keep the truck another 15-20K miles.
I didn't open the filter up. I was too worried about the yellow plastic piece I found laying loose in the pan. Duh!!! I know what it is now. LOL
If it's converter only, I'll replace it myself. I'll let the house budget buy me a trans jack.
Just didn't want to do the converter and then have to buy another one in 10K miles if the trans dies.
Ford tailshaft questions 4R70W vs. AOD Nonhog Transmission - Rearend 1 01-26-2011 03:12 PM
Ford 4R70W torque converter interchange? sweet99 Transmission - Rearend 1 11-09-2006 04:04 PM
4R70W no go dbdbb Transmission - Rearend 2 09-09-2006 10:38 PM
Ford 4R70W Transmission won't shift 2-3 Arrowhead Transmission - Rearend 2 04-30-2006 06:22 PM
4R70W 00stang Transmission - Rearend 2 08-24-2002 09:32 PM
