Ford 4R70W torque converter interchange? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-09-2006, 02:51 PM
My '99 Mustang has the 4R70W automatic tranny with OD. It has a 12" converter and about an 1800rpm stall speed. Lincolns with the 4.6 "Hi-Po" motors had an 11" converter. This info I got from a fellow who reworks converters. The Lincoln converter has around a 1000 greater stall speed.
I am trying to find out one of 2 things that would allow a change to work.
1. Is the Mustang flexplate also drilled and tapped for the 11" converter which has a different bolt pattern?
2. Would the Lincoln flexplate bolt to my crank and have the same diameter as the Mustang flexplate so I could use the Lincoln plate and converter in the Mustang?
Any help or direction is appreciated, Mark
Old 11-09-2006, 03:04 PM
aka Duke of URL
WHEW!
The LINC 4.6L is DOHC. Your is?
The convertor is controlled by the PCM. You need exact info on this one.
Contact -BAUMANN ENGINEERING- and see if they can advise you. That or FORD RACING TECH.
Torque Converter Question leejoy Transmission - Rearend 5 10-02-2006 11:57 AM
Building a SBC to rev to 8k, and have power Andyrew Engine 52 04-17-2006 12:46 PM
torque converter IDENTIFICATION 327amc Transmission - Rearend 5 03-26-2005 06:23 PM
Is my jeg's brand torque converter a dud? elukas Transmission - Rearend 5 10-07-2004 11:08 AM
C5 or Torque Converter Bad? k2mooch Transmission - Rearend 2 11-30-2003 08:27 PM
