Ford 5.0 Explorer Swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-29-2011, 03:54 PM
So I no I hashed this out a few weeks ago but.
I have a 95 f-150 5.0. It runs great, and burns zero oil problem is its gutless.
So in my endeavors as a mechanic I have recently been able if I'd like to aquire a 99 explorer intake set for 110 dollars. I know its a popular bolt on on the GT motors but will it work for the conventional truck engine?
Also with a TB and all will I need to do anything except a few minor drill and tap situations? Thanks. Sorry I am not so well versed.
BTW I am a technician by trade and the drilling, soldering etc. is 2nd nature and I guess I have to much tinkering time on my hands. LOL.
Old 01-29-2011, 04:01 PM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
The explorer intake is a low profile like the HO (mustang) so itcan clear the hood profile. I would adress the performance issue as it is on the vehicle( the f 150) or your just throwing parts at the real problem and chances are it wont run any different.
Old 01-29-2011, 08:36 PM
Explorers are good street intake that make the best torque of any intake, stock or otherwise. I've got an explorer upper on a GT40-351 lower just port matched upper to lower on a 351 with Edelbrock heads and a fairly decent cam and it feeds that engine really well.
Here's a test that verifies what I say
http://www.musclemustangfastfords.co...per/index.html
The bottom is a GT40 piece, the upper is nearly identical in flow to the tubular GT40 or the Cobra.
It should give you somewhat of a torque boost, but with your stock cam and heads you won't get the anywhere near the most out of it. Stock heads are as big a choke as your stock intake.
You could gain some power inexpensively by finding a good used H.O. Mustang cam and adding 1.7 rockers for more lift. Now if you could get the explorer heads with that intake then you'd have a better matched H/C/I and would then be getting a good increase in power and torque for a reasonable investment. Some used headers would help, too.
Explorer differential Swap Help sixty9santa Transmission - Rearend 7 02-05-2009 07:25 AM
New here, with 9" Explorer disc brake swap ??? montegoman351 Suspension - Brakes - Steering 6 06-22-2007 04:35 PM
ford explorer bolt_boy_49 Transmission - Rearend 4 03-26-2007 09:15 AM
o/t ? ford explorer sport. FEDDO General Rodding Tech 3 02-18-2007 04:41 PM
91 v6 ford explorer timing off druid Engine 1 03-04-2005 06:14 AM
