ford 5.0 heater hose - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-02-2008, 10:14 AM
ok, here go'es. when i took the engine out of a mustang, i disconnected the heater hose's and forgot where they go.i have 2 coming out of the water pump about 2 inches apart, 1 out of the front of the manifold, and 1 out of the front of the block above the water pump.
who knows fords and can guide me?
Old 03-02-2008, 12:45 PM
re:ford 5.0 heater hose
Hi l hope l remember this right? block goes to left side water pump, right side water pump goes to heater, bottom heater hose goes to manifold, l hope thats right don't have any kicking around anymore or l'd look TROY
Old 03-02-2008, 02:57 PM
jvsutton's Avatar
Bean Counter
Last journal entry: Paint time
On mine the bottom one of the two little fittings on the left side of the water pump has a little hose that runs right up the intake in the thermostat housing, the other runs to the heater core and the other side of the heater core connects to the fitting on the top of the intake. I hope this helps! let me know if you need a pic
Old 03-02-2008, 09:53 PM
thanks for the answers,, : i will give it a whirl.
Old 05-02-2008, 08:27 PM
i need pic of hoses coming out of fire wall runing to water pump and top of engine
Lincoln LSC 5.0 HO into 1966 ford GTA ?? SSuperwrench Engine 7 02-09-2007 05:08 PM
Banjo fitting illegal?? gavinpierce Hotrodding Basics 10 04-22-2006 11:08 AM
Ford 302, 5.0 Engine timing Tanker27th Engine 5 03-06-2006 09:24 AM
ford 5.0 HO oldblue4x4 Engine 2 12-28-2003 08:06 PM
Ford 5.0 & 4.6 bolt patterns deleteall Engine 1 06-29-2003 05:25 PM
