Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ford 5.0 internal specs
Old 10-05-2002, 01:14 AM
mustang66maniac's Avatar
mustang66maniac mustang66maniac is offline
Ford Freak
Post
if its not a HO then it doesn't have forged pistons. The crank is the same, i dont know about the conecting rods though. You can put heads and intake on it to make it an HO along with a roller cam, then change the firing order and of course forged pistons. I have a set of E7TEs (87-93mustang heads) if you want to buy them off me. If you have a roller cam block, it will take both flat tappet cam/lifters and roller tappet cam/lifters. If you put in a roller cam you will need the spider assembly to keep the lifters from twisting. If I were you I would just grap an ECM from a wrecked mustang.
