Ford 5.4 computer problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-22-2010, 08:34 PM
I have a 2004 f150 with a 5.4 engine. It had a bad computer. It would rub till hot then quit if you cooled the ecm with ice it would start right up.
I replaced the ecm with a reman. now it wont energise the starter. It shows no fault codes. door locks workk fine. Alarm system seems to work ok. Got any ideas I am stumped.
Thanks Mark
Old 11-23-2010, 12:59 AM
47dodge's Avatar
Last journal entry: 1947 dodge
This is just a guess and I could be completely wrong but Fords after about 2000 used an RFID chip in the key. With a new computer I think you will have to have the computer programmed to work with your key. Each key you have would have to be programmed in.
Old 11-23-2010, 09:51 PM
5.4 computer
Hi 47 dodge
You were right. I wasn't aware that in addition to flashing the computer it had to have the keys reset.
Thanks for the answer.
Mark
Ford 400 Cooling System Problem My79Ford400ciF1504x4 Engine 4 09-29-2010 10:09 AM
got a clearance to frame problem with a Ford Starter Berg Engine 4 05-10-2010 03:36 PM
starting problem --4.6L in 49 ford wmrdalydvm Electrical 5 11-18-2009 01:17 AM
94 Ford Problem DoubleVision Engine 2 06-06-2004 06:13 AM
Computer Problem kristkustoms Hotrodders' Lounge 4 10-04-2003 08:33 AM
