Ford 5.4 swap
Is there an aftermarket harness option for a Ford 5.4 swap into a rock crawler project?
Doc here,
What platform for a rock crawler? And 5.4 ...I'm not a Ford guy..What is that? I know GM 5.7 is 350..and 5.0 is 305... just what do you need to run? you might be able to build it yourself if the wire count is low using a replacement fuse block.. Doc
Aftermarket Solutions Electronic & Electrical Innovations Last edited by docvette; 12-30-2005 at 09:14 PM. Reason: cuz I can....... |
You're talking about the modular 5.4L out of the newer Ford pickups, yes?
If that's the case, then the guys over at http://www.modularfords.com/ can help you out. There are a few that put the 4.6/5.4 engines into older machines. I believe you will 'just' need the factory harness and PCM. I am unaware of any aftermarket wiring harnesses for the mod motors at this time. It's a lot of work, but the results would be great. |
| Questions on the Ford 4.6 DOHC and 5.4 DOHC | Nightfire | Hotrodding Basics | 21 | 09-25-2011 06:15 PM |
| 2001 Ford SOHC 4.0L V6 engine swap | metrobill | Electrical | 10 | 02-20-2004 08:15 AM |
| Ford alternator pully swap | FAIRLANE DUDE | Electrical | 1 | 05-09-2003 12:34 PM |
| Ford Straight 6 swap to a 302 or 351 | BillyBob1950 | Engine | 5 | 01-18-2003 02:42 PM |
| 63 ford pickup 292 to 351 swap | crbird | Engine | 2 | 01-14-2003 10:42 AM |
