Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ford 532 stroker
Old 05-08-2005, 06:49 PM
FEDDO's Avatar
FEDDO FEDDO is offline
385 series
I would never buy std bore pistons. where will you find another std bore block if something goes wrong. and the myth that you can only bore.060 on a 385 series. I ran a .060 with a stroker crank and had no problems. when that block cracked in the main webs I had pistons that would fit another block. just a thought.
