Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ford 5x5 1/2 bolt pattern
Old 10-28-2012, 08:05 AM
timothale timothale is offline
Wiki Edits: 27
rear brakes.
I haven't researched it recently, I have some F 1 spindles, model A front Axle in the parts pile. I printed out the Info From the Hamb site on what parts to use to have self adjusting brakes and what the replacement part numbers are since most parts stores don't go back that Far. Also on the Hamb There is information on using Later model Chevy station wagon 12 " rear brakes on old Fords, and I think some other GM 12 " brake parts Fit. A lot of the Axle tubes are modified to use newer axles and bearings, get away from the old taper Shaft ends and keys,
