7.5 Ford
First, I think youre 1992 Ranger may have a 8.8 rear instead of the 7.5 you mentioned. You can check this out for sure by the data plate on your truck. Also, check out www.therangerstation.com for some good information.
Second, they didnt use gaskets for the rear cover,just silicone. This is a big job requiring special tools to set the gear pattern. I would take it to a garage. You didnt mention if your truck was a 4X4 or not . If it is, you'll need the same gear ratio for the front as the back. Hope this helps |
Thanks for the tip.It's a 2WD.I'll probably end up letting my cousin do the job.He has everything that one needs to do such a thing.I'm sure that my rear is a 7.5".I ran the numbers on the tag when I bought it in August and everything checked out.The only Ranger's that they put the 8.8" rears on 1989+ was the 4.0L V6 models.Mine has the 2.3L 4-Banger
.Still,a 4.10 Gear Ratio would be ALOT better than the original 3.07 ratio Nightrain |
