ford 7.5 swap to 8.8 86-93? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-25-2005, 05:21 PM
malibu68's Avatar
I have a 85 mustang 5.0 gt and its got a 7.5 posi and i want to swap that out for a 8.8 but we want to know if its as easy as it sounds, If anyone has any info on this that would great.
Old 03-25-2005, 07:02 PM
tbirdscott's Avatar
stuff'n things'n whatnot
If the 8.8 is out of a fox body aswell it will bolt right in. The brake line may switch sides in some applications and widths can vary, keep that in mind when shopping.
Old 03-25-2005, 09:40 PM
Watch out for later ('87-'88) Fox T-bird Turbo Coupe/Cougar XR-7 8.8" rears. They are ~1.5" wider than Mustang rears, & that might cause a clearance problem.
Ford 8.8 , Lucas Syn. need Ford additive? Frank K Transmission - Rearend 6 08-16-2004 03:03 PM
striaght 6 swap into a 55 ford truck brett 6868 General Rodding Tech 1 06-11-2004 11:51 AM
Ford Straight 6 swap to a 302 or 351 BillyBob1950 Engine 5 01-18-2003 03:42 PM
63 ford pickup 292 to 351 swap crbird Engine 2 01-14-2003 11:42 AM
Ford 8.8 4-lug to 5-lug disc swap ?? 49 T&C Transmission - Rearend 1 09-17-2002 09:25 AM
