Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ford 8.8 Explorer rearend spring perches?
Old 09-17-2009, 11:54 AM
chieftain chieftain is offline
Another reason I made my own was my springs were too narrow for the factory 8.8 perches or ones available that were 3" tube. I needed the narrower perch for the bolt pattern to fit in between my lower spring plates which have the lower shock mount. As long as the centering pin isn't more than 1/2" tall the 2 x 4" will work . If you need a pair made pm me.
