Ford 8.8 Explorer Rotors with 5x4.75" - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-13-2011, 05:01 PM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
I was wondering if there were any rotors I can get right down at like Autozone or online for the same price as regular rotors that will have the 5x4.75" bolt patter but fit the explorer rear end. I am putting this rearend in my car and I already drilled the axles for the bolt pattern of my wheels. If not no biggie I will just buy a wheel pattern template and drill them myself.
http://www.summitracing.com/parts/MFY-8021392/?rtype=10
Old 05-13-2011, 05:55 PM
SSedan64's Avatar
This needs to be very accurate or you'll get vibes.
I would'nt atempt it without an Indexing Head on a Mill or Lathe. Machine shop can redrill your Rotors, Axles, Drums. Or they may be available with the GM pattern, aftermarket.
Old 05-13-2011, 10:52 PM
Listen and Learn
Wiki Edits: 7
Thats what im looking for.
Old 05-14-2011, 08:33 AM
Wiki Edits: 27
drill transfer punch ?
If the explorer axle has already been redrilled and is acurate bolt on the exp rotor and use a transfer punch and carefully redrill.
What rotors do I have on Ford 9" redride Suspension - Brakes - Steering 5 08-16-2009 07:07 PM
Explorer 8.8" in a '76 Granada - Doable? sixty9santa Transmission - Rearend 4 07-16-2009 09:34 PM
New here, with 9" Explorer disc brake swap ??? montegoman351 Suspension - Brakes - Steering 6 06-22-2007 05:35 PM
Explorer Disc Bbrakes on a 9" Ford Rear End Mustangsaly Suspension - Brakes - Steering 2 10-31-2005 05:18 PM
Best Ford caliper for 11" rotors on Mus II IFS Darkman270 Suspension - Brakes - Steering 12 03-06-2004 05:20 PM
