Ford 8.8 Posi disassemble questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-29-2013, 02:11 AM
Kermitt47's Avatar
I am trying to take my Ford Explorer 8.8 Posi unit apart to replace the clutches and cannot get the locking bolt out so I can remove the spider gear pin. Does anyone have some tricks for removing this bolt?
Thanks
Old 03-29-2013, 07:39 AM
big gear head's Avatar
High Performance Rear Ends
What is the problem? Why can you not get it out?
Old 03-29-2013, 09:13 AM
kso's Avatar
kso kso is offline
I had a good 'ol time with that recently, but finally got it after having a tug-of-war with the old Loctite. Gotta use a six-point tool, not a twelve...sometimes on one of those bolts with tiny heads, if I don't have a six-point wrench and a ratchet won't fit I'll take a six-point socket and weld a handle onto it, and just call that a dedicated tool then.
Old 03-29-2013, 09:36 AM
If the pin/bolt is broke, you can drill a small hole at the other end and probably blow the broken part out with air (after the bolt part is removed).
Old 04-01-2013, 05:22 PM
If you have not rounded off the bolt head yet, here is what I would recommend:
Take a hand held propane torch and heat the carrier up right where the threads are. This will "release" the loc-tite temporarily. While it is still hot, using the CORRECT socket and maybe an extension so as to move your impact gun away from the carrier, hit it with a good 3/8" impact gun and it will come right out. If you have rounded the head of the bolt off already.. Well.. Break out a cold chisel and try and move the bolt head in a counter-clockwise direction. Order new bolt. Problem solved.
If you think getting that bolt out is fun, wait until you try and roll the side gears w/clutch packs out of the carrier. That's REAL fun! The FERD 9.75" are great fun to learn on.. Just saying. I can't count how many Ford diffs I've had to replace the clutches on because of groaning when turning sharp corners.
Eaton posi questions... ap72 Transmission - Rearend 7 06-23-2008 07:35 PM
GM 10-bolt 7.5 posi questions... 67cuda Transmission - Rearend 2 03-20-2006 08:41 PM
1937 ford truck hood disassemble magnum2u Body - Exterior 3 09-21-2004 11:39 PM
some questions about posi's Dreadlord Transmission - Rearend 4 02-03-2004 12:31 AM
9 inch Ford disassemble procedure 38 ford 4 door Transmission - Rearend 2 04-03-2003 11:31 PM
