Ford 8.8 rear end and mini spool... axle pops out - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-14-2008, 01:44 AM
chevyluv77's Avatar
Yea! Just Yank it Out!
Ok heres my problem..
I have a 1977 Chevy Luv with a 350 stock motor,
and a turbo 350 trans 3000 stall and US Strange gears,
and a ford 8.8 rearend with Richmond 3.83 Gears and a US Strange Mini Spool.
Now i do understand driving with a spool on the street is not so fun..
but i do. and thats where my problem is.
my passenger side axle pops out..
i know that fords dont have C clips and the first time it happened i replaced
the outer axle bearing,
but every 2 miles, turning or not it still spits my axle out,
i checked my spine and it looks perfect.
I Need Help Please!
Old 01-14-2008, 08:56 AM
I think all 8.8 integral housing rears use c-clips. Does the outer bearing press on to the axle shaft and is then retained in the housing by four bolts? Most mini spools will accept the c-clips. You might want to take this to a pro. And if only one side is coming out, you have a tracking issue.
Old 01-14-2008, 01:36 PM
S10xGN's Avatar
Gotta love a turbo!
On a (stock) 8.8" Ford, the c-clips are the only thing that hold the axle in! Whoever installed the mini-spool either forgot the c-clips or didn't think they were important...
Russ
Old 01-14-2008, 02:22 PM
chevyluv77's Avatar
Ford 8.8.. Mini Spool.. Axle Pops Out!
Yes the bearing had to be pressed on and the vacuum plate with the four bolts was still bolted down..
i thought fords dont come with C clips?
i took it down to Six States one of the Local Specialty shops
and they thought the same as i did..
I've had them press on the bearing twice now.
Its starting to get pretty annoying..
anything else you have in mind?
Old 01-14-2008, 02:55 PM
S10xGN's Avatar
Gotta love a turbo!
First, make sure your's is a Ford 8.8" (see pix). If so, run like h*ll as far and as fast as you can away from that shop as they are truely clueless!
Russ
ID:	27033   Click image for larger version
Old 01-14-2008, 03:13 PM
chevyluv77's Avatar
My Crazy Problem
Oh my bad, it is a Ford 8 in.
Either way would it make a very big difference?
Im only 18 so i am still learning..
Old 01-14-2008, 03:31 PM
S10xGN's Avatar
Gotta love a turbo!
Much different, the 8" rear does use the bearings to retain the axles. Possibly the axle shaft is worn enough so the retainer collar comes loose or they're using the wrong collar. There should be a sizeable interference fit there. It could be as simple as pressing on an undersized collar (if there is such a thing) or complicated as buying new axles(s).
Russ
Old 01-14-2008, 03:45 PM
chevyluv77's Avatar
My Crazy Problem
I was thinking that it might be the wrong bearing.
But i double checked and its the exact same part number.
maybe i will have to just replace the axles?
Old 01-14-2008, 03:57 PM
S10xGN's Avatar
Gotta love a turbo!
The bearing does not hold the axle, there is supposed to be a collar that presses onto the shaft after you slide the bearing on. Best to find a good blow-up diagram...
Russ
Old 01-14-2008, 04:11 PM
chevyluv77's Avatar
Oh! ok i see what you mean now..
When i put that Collar/Retainer piece on is just slide up and down..
You are supposed to put that on after you have the bearing pressed right?
Old 01-14-2008, 06:13 PM
The lock collar comes with the new bearing and should be a lot harder to press on than the bearing, because you dont want to deform the inner race of the bearing too much. Sometimes, though I dont like to, if the axle is worn, you can tack weld the collar to the axle. It only takes A REALLY SMALL TACK and can be done with a TIG welder to minimize the heating of the axle shaft.
Old 01-14-2008, 06:31 PM
chevyluv77's Avatar
Ok does the collar go on before the bearing?
Because once i press the bearing on that collar has nothing to stick to.
It just slides.
Could the shop and i be putting it on back wards?
And if it comes down to worn axles id rather replace them then
weld them.
Thanks for your guys input.
Old 01-15-2008, 12:36 AM
chevyluv77's Avatar
I've looked around a bit for some replacement axles..
its been about a 7 hour journey but i cant find anyone that sells them.
Anyone know of a place that would possibly sell replacement 8 inch axle shafts.
Old 01-15-2008, 05:39 AM
S10xGN's Avatar
Gotta love a turbo!
Here's a pic of a 9", the 8" is the same. The collar goes on last and is a very tight press fit.
Russ
Old 01-15-2008, 12:59 PM
8 and 9 inch 28 spline axles are the same all you need to know is the brake offset (flange to bearing outer surface) and the housing end you have (early/late big or small or car/mustang end) they will interchange.
Mini tub, narrow rear first or buy wheels first? CHASINGJR Transmission - Rearend 3 09-20-2006 12:21 PM
difference/pros/cons of spool and mini spool? "70" Cougar Transmission - Rearend 20 03-03-2006 11:42 AM
mini spool camino_man Transmission - Rearend 3 02-08-2004 07:34 PM
Jag Rear End Advice farna Transmission - Rearend 3 06-13-2003 07:52 PM
Is a 7.5 10 bolt rear end with 350/350 set up ok? MuscleBlock81 Transmission - Rearend 4 03-27-2003 05:45 PM
