Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ford 8.8" rear end slop
Old 07-15-2012, 01:46 PM
big gear head's Avatar
big gear head big gear head is offline
High Performance Rear Ends
There is no way to tell by turning the pinion. The only way to accurately measure backlash is by setting up a dial indicator like the one in the picture that I posted. When you check backlash you MUST hold the pinion COMPLETELY still. If the pinion moves the slightest bit then your measurement will be wrong.
