Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ford 8.8" rear end slop
Old 07-15-2012, 05:41 PM
big gear head's Avatar
big gear head big gear head is online now
High Performance Rear Ends
Were the gears installed by someone who knows how to set up gears? If the job was done right then there is probably nothing to worry about. If they were installed by someone who doesn't know how to set the pinion depth, bearing preload and backlash then you need to check it out.
