Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ford 8.8 Rear U-Joints
Old 11-09-2012, 07:47 AM
big gear head's Avatar
big gear head big gear head is offline
High Performance Rear Ends
The NHRA wouldn't be very happy with that. Is there any way to move the fuel cell away from the drive shaft? If you break a u joint you are going to scatter fuel everywhere. The Exporer rear end has a lot of pinion offset. Maybe you should have one end of the housing shortened to get the pinion centered and that would move the pinion away from the fuel cell. I know that's not a cheap or easy fix, but it might be the best thing to do.
