ford 8.8 truss system for g body. - Page 6 - Hot Rod Forum : Hotrodders Bulletin Board
  #76 (permalink)
Old 06-08-2011, 05:09 PM
TroyBoy's Avatar
Psychomotors
Pretty good thread I got a 79 Bu and now you got me thinking,lol.
  #77 (permalink)
Old 06-08-2011, 08:42 PM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
Its a great rearend but the offset might get the best of me. I gotta look at the Driveshaft tomorrow and see if it hits the tunnel.... but ill lost pics tomorrow of the rearend in place.
  #78 (permalink)
Old 06-30-2011, 08:26 AM
Listen and Learn
Wiki Edits: 7
Well the rearend is all done. Just need to finish bending the brake lines and get the driveshaft made. When the rearend was in place and mounted up I put the old driveshaft in and it wasn't hitting the floor at all. I even put the driveshaft on top of the pinion flange to account for rearend travel.
Heres the uca welded in place. I got a piece of 1/4" steel by 2" wide and put a flat piece across the top and welded two braces coming down from each side. I am also putting two pieces straight down that will bolt to the cast housing.
  #79 (permalink)
Old 07-11-2011, 05:01 PM
Listen and Learn
Wiki Edits: 7
Shes sitting on all four again!!!!! Thanks again for all the help everyone! This has been such a great project to undertake. I have learned so much from doing this and have really enjoyed it... Im gonna wait till the end of the year and see how this holds up and if all is well I am going to make a couple more of these to help improve the design I came up with.. maybe throw a couple on ebay to give other people with g-bodies an affordable bolt in rear end that is easy to come across unlike the 8.5", 12 bolt and 9" rearend.
I am gonna order the drive shaft tomorrow and hopefully soon i will have some youtube videos of me beating on it around town .
  #80 (permalink)
Old 11-29-2011, 11:49 AM
Do you have any pictures of the down-bars you added to bolt to the housing?
  #81 (permalink)
Old 11-29-2011, 12:15 PM
Listen and Learn
Wiki Edits: 7
are you talking about the lower control arm mounts?
  #82 (permalink)
Old 11-29-2011, 12:18 PM
Originally Posted by zildjian4life218
.....I am also putting two pieces straight down that will bolt to the cast housing.
No, was referring to the additional bracing you mentioned above, going from the UCA mount down to the housing so that it would bolt on (I assume for additional strength)
  #83 (permalink)
Old 11-29-2011, 12:22 PM
Listen and Learn
Wiki Edits: 7
Ah ok. Yeah I'm in class now so ill post them later when I get done for the day.
  #84 (permalink)
Old 11-29-2011, 12:41 PM
big gear head's Avatar
High Performance Rear Ends
I noticed that you welded the axle tubes to the center casting. Did you use nickel when you did this?
  #85 (permalink)
Old 11-30-2011, 07:08 AM
TroyBoy's Avatar
Psychomotors
Sounds like a winner. Hope its been working good.
Amateur paint and body - filter system Highway Body - Exterior 3 11-10-2008 12:01 PM
Dual throttle body injection system RONNYinWAXHAW Engine 17 11-27-2007 05:47 PM
For those that know roof truss stuff... schnitz Garage - Tools 10 11-02-2007 08:00 PM
Garage Truss Suggestions JhnBrackett Garage - Tools 4 05-22-2007 09:15 AM
Airaid intake system and throttle body spacer bracketeer Engine 4 06-17-2005 10:37 AM
